Ana içeriğe geç
Released April 2010 / 2.4, 2.53 GHz Core i5 or 2.66 GHz Core i7 Processors
590 Soru Tümünü görüntüle
The MacBook Pro wont boot and directly goes to the question mark!
My Macbook pro recently stopped booting into Yosemite and directly goes to the folder with a question mark on it. I have tried 3 things,
1. Holding the option key while turning on to select partition to boot in
2. Holding the command+R keys to boot into recovery mode and try to reset OS X
3. Unplugging and re-plugging the hard drive cable
When I opened disk utility in recovery mode the entire partition where my OS X would be is gone and all that is left is a 2GB recovery partition.
My question is whether or not I need to get a new hard drive. Is it dead and is there anyway I can test that? I would like to be able to fix the hard drive and resort to buying a new one as last option. I realize that this problem could also be a faulty hard drive cable and I would have to change that first. Is there any way to know what my problem is specifically?
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
First pull the drive and use an external enclosure or a USB to SATA adapter and see if it is accessible that way. If so, replace the hard drive/IR cable with a new one from a 2012 13" model.
Bu yanıt yardımcı oldu mu?
Puan 2
1 Yorum:
I will try this as soon as possible thank you!
tarafından
Yorum Ekle
when its booting up, hold command and R. a globe will appear and it will say internet recovery. then it will boot into mac os utilities. click reinstall mac os and follow the onscreen instructions.
Puan 0
Yorum Ekle
Yanıtını ekle
Timothee Legros sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 3
Her zaman: 80
