Part number for power management IC
My device doens't turn ON, it is charging and battery shows the voltage after tearing down. Seems like battery management IC got burnt. Does someone know the part number and manufacturer of this IC?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
4 Yorum:
@bas77 have you tried a different battery? The power manamgement IC is usually not the first component to check the no power on situation.. Post some images of your circuit board (front and back) with your question. It may help us to identify certain parts. Use this guide Mevcut bir soruya görsel ekleme for that
tarafından
Is the phone drawing power from the usb socket?
tarafından
Yes. I've checked the battery voltage.
tarafından
@oldturkey03 I've tried different battery. battery doesn't have any problem. I don't have a SMD soldering station right now. If you know the part number of the IC, it will be helpful. Ineed to check the availability. I will get it soldered from others.
tarafından
Yorum Ekle
