Ana içeriğe geç
iPhone'un 5. jenerasyonu. Cihazın onarımı basittir; tornavidalar, kanırtma aletleri ve sabır gerektirir. GSM/CDMA / 16, 32 ya da 64 GB / Siyah ya da Beyaz.
White screen with lines
Replaced the 3.5 jack and harness, as I've done 2 other times. This time though, when i powered back up, the screen was white with a few dark blueish verticle lines on left side of screen and small horizontal lines on entire screen. What could have happened??
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
1 Yorum:
Probably the lcd ribbon / flex cable damaged which in results in needing a new screen.
tarafından
Yorum Ekle
2 Cevap
Filtre ölçütü:
try this
Press and hold the home button, then the up-volume button, then the sleep/power button (so all three buttons are now pressed and held) --- it takes a while, but the white screen will go away and then after another 10 seconds or so (still holding btw!) the apple logo will come up, release the buttons and then wait, it'll boot normally again in a minute or two.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Try disconnecting the LCD connector and reconnecting it (make sure the battery is disconnected while you do this) just in case it came loose. If that doesn't work, then you will need to replace the screen.
Puan 0
Yorum Ekle
Yanıtını ekle
mandalorian75 sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 4
Her zaman: 554
