Ana içeriğe geç
How to remove Oil marks from display
Hello Friends ! I have Xperia z3 compact..recently i spilled hair oil on its display...so it got some white marks on lower left corner..touch is working absolutely fine and so is everything.but i want to remove those white marks..is it possible, suggest all available option to remove those marks.... please help its really urgent guys
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
The issue you're running into is, the oil seeped into the backlight behind your LCD display. The only way to remove the oil is to get your backlight replaced or your entire LCD assembly replaced.
Bu yanıt yardımcı oldu mu?
Puan 0
2 Yorum:
Thank u Friend,, but there must be some other way as well...can u please recommend any other method bcz at last i will replace whole lcd if nothing works out
tarafından
Unfortunately, since it's an oil based liquid, I don't think you'll be able to dry it out. :( Good luck to you! If you need help with a repair, we accept mail-in repairs at our shop!
tarafından
Yorum Ekle
Yanıtını ekle
mail4dueds sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 11
Her zaman: 170
