Ana içeriğe geç
The BLU Vivo 5 is an Android smartphone produced by BLU, an American consumer electronics company. The 5 was produced through a partnership between BLU and Vivo Communication Technology Co. Ltd., a Chinese technology company. The BLU Vivo 5 was released in February 2016.
42 Soru Tümünü görüntüle
Where did my call log and messages go?
So I have all of my contacts but all of my messages and call logs disappeared. When I go to my settings it says I have all of my messages but when I open the app or hangouts I have zero threads. It will also notify me when I have a new text message but I cannot see said text anywhere. I tried resetting my messaging settings and it didn't work. I'm incredibly confused. Help?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 8
3 Yorum
I have a vivo y21l phone but after 4 months of buying it does not show any recent calls and missed calls rather it shows old calls what to do next..
tarafından
Have you solved this problem? It happened to me. But i still cant fix it
tarafından
Hello
I have vivo v5 and i was block a number and the block number and messages remove from my message inbox.
My all messages go in to i manager block messages.
I want to move that all messages from i manager block message inbox to my vivo v5 default message inbox after unblock that number.
How to fix this issue please help me to fix this issue.
Thanks
tarafından
Yorum Ekle
11 Cevap
Filtre ölçütü:
En Yararlı Yanıt
It may be because you accidentally turn on the "guest mode".
My sister also has a vivo 5 and experience pretty much the same problem. She can't see any call log, and all the picture in the album are gone.
In the file explorer I was able to find the pic under DCIM folder, but don't have the access to view it. The phone pop me a message saying I was not allow to see them because I was in the guest mode.
So I go to setting->security-> and turn off "guest mode". Everything come back, hope it also work for you.
Bu yanıt yardımcı oldu mu?
Puan 25
22 Yorum:
Oh. Fantastic. Thank you very much for your suggestion. I had the same problem and I very much worried. After seeing your suggestion and tried off from guest mode. I the problem solved. Thank you very much.
tarafından
Thanks you I turned off my guest mode like you suggested and my call and messages are back,, thank you sooooo much
tarafından
I can't find the guest mode on my Vivo 5R.
Can someone help me ASAP. Justice
tarafından
I can't find guest mode either, any help?
tarafından
Thanks.... It works
tarafından
17 tane daha yorum göster
Yorum Ekle
Justice Sackey I emailed Blu support and they told me to go to settings, security, unknown apps installed, open it download guest mode doc, then you can close that setting back to unopen. It worked I got everything back.
Puan 0
5 Yorum:
What is the process of delete call log in vivo v5 phone
tarafından
@aliceca , I have same problem with 5R, I cannot find "unknown apps installed". Is it hidden under other section? Thanks.
tarafından
After the phone being updated to the latest version *v24_generic_6.0_07-6-2017, the "Guest-Mode" check box showed up on "Settings" - "Security". Finally, I got the call logs back.
tarafından
I'm experiencing the same problem. I am unable to find any of the options in security, and not sure how to get the phone to update as mentioned above. Would be grateful for any suggestions... cheers
tarafından
I have an XL2 with the same problem, I followed the instructions and got everthing back. Thanks @dzpcool!
tarafından
Yorum Ekle
Thanks for this info...I now have my messages, pictures and call log back.
Puan 0
Yorum Ekle
It worked for me .Thanks
Puan 0
1 Yorum:
hey everyone, I have vivo xl and after a certain date I have lost some messages. I never lost my call log or contacts... HELP!
tarafından
Yorum Ekle
This is probably because your guest mode is turned on. Go to settings>security>guest mode and turn it off. Hope it works for you.
Puan 0
1 Yorum:
It doesn't have that option when I click security
tarafından
Yorum Ekle
Hello
Thanks
Puan 0
Yorum Ekle
I have Lenovo k6 note with venom os
I can't see my recent calls and messages..
What to do ??
Puan 0
Yorum Ekle
Same here. I can't see my call log or pictures.
Puan 0
Yorum Ekle
Your a deleted it or your phone glitches out. Don’t be too hard on your self, computers are complicated.
Puan 0
Yorum Ekle
I can not see the Miss calls numbers on my
Puan 0
Yorum Ekle
Thank you,
Your answer to the problem worked like a charm. Resolved within 30 seconds vs. my having spent a lot of useless time before reading your answer. Thanks again. Mike M 3/25/2020
Puan 0
Yorum Ekle
Yanıtını ekle
Angie kriess sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 7
Her zaman: 34,942
