Ana içeriğe geç
Repair guides and support for top and front loading Whirlpool brand washers.
425 Soru Tümünü görüntüle
Does not spin in spin cycle or does not spin fast enough
Hello, I have an Inglis Whirlpool large capacity top load washing machine. I bought it new in 2006 which makes it a 10 yr old machine. I'm having 2 problems with it now. First: the spin cycle will either spin too slow to get the water out or it doesn't spin at all. I reset it by unplugging it for a few minutes & plugging it back in & opening/closing the lid a few times then running it through a small cycle, which it then spins. (I read resetting it like that can help, which it did for a while) I wash a new load & sometimes it works, sometimes it doesn't. It agitates fine in wash cycle. I've been washing only a couple items at a time hoping it'll spin, but it doesn't. So I do the lid reset & try again. Most times now, it doesn't work.
Second: almost every time at the beginning of the spin cycle it'll start adding water! Then it'll go into the spin cycle after. Sometimes it spins, slowly, but most times it doesn't spin at all. Please help. I don't have the money to buy a new one so I'm really hoping I can fix it myself
Thank you!
Bu iyi bir soru mu?
Puan 1
6 Yorum
@sandylittle314 what is your exact model number?
tarafından
I am having the same problem with my washer machine, It fills, agitates and drains, but does not spin. I unplug it for a few minutes, plug it back in, put in on drain and spin cycle, then it spins. Not sure what the problem it since unplugging it then plugging it back it can get the spin cycle to work, thinking something with the timer?
tarafından
zantor please ask a new question on your specific problem
tarafından
Due to a heavy wet load.
My washer spins but slow. Checked belt, looks fine. Belt turns at an ok speed then slows down and I smell something. Any help?
tarafından
motor on its way out time to replace
tarafından
1 tane daha yorum göster
Yorum Ekle
5 Cevap
Filtre ölçütü:
Seçilen Çözüm
Cause 1
Motor Coupling
The motor coupling connects the motor to the washer transmission. If the washer is overloaded, the motor coupling will fail in order to protect both the motor and transmission. The motor coupling can also fail due to normal wear. Inspect the motor coupling to determine if it is broken. If the motor coupling is broken, replace it.
Cause 2
Drive Belt
Inspect the drive belt to determine if it is broken or if it is loose on the pulleys. If the drive belt is broken or loose, replace it.
Bu yanıt yardımcı oldu mu?
Puan 2
1 Yorum:
It leaves the towels wet. With clothes no issues.
tarafından
Yorum Ekle
check capacitor may be faulty
Puan 1
1 Yorum:
capacitor has ageing effect..it becomes weak..after long time uses.
tarafından
Yorum Ekle
If I hand spin it at times it catches and spins fast. One in 10 times. Could that still be the coupling
Puan 0
Yorum Ekle
2 big reasons is loose belt that will slip & will not get into full spin AND the number one reason is defective lid switch! Wire falls off or switch fails then it will not go into spin cycle (thinking the lid is open).
Puan 0
2 Yorum:
If the lid switch is defective it shouldn't spin at all right? Mine spins but the clothes are still wet. Nothing is clogged.
tarafından
will not spin at all if lid switch is not working
tarafından
Yorum Ekle
Yes the capacitor has got ageing effect. Try replacing it with new one.
Puan 0
Yorum Ekle
Yanıtını ekle
Cassandra Little sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 13
Son 7 gün: 85
Son 30 gün: 380
Her zaman: 73,302
