Ana içeriğe geç
23 Haziran 1996'da piyasaya sürülen ve NUS-001 model numarasına sahip olan N64, Nintendo'nun ilk 64-bit oyun konsoludur ve Switch'in piyasaya sürülmesine kadar tek 64-bit konsolu olmuştur (GameCube, Wii ve Wii U, 64-bit kayan noktalı işlemler gerçekleştirebiliyordu ancak bu, gerçek 64-bit mimarisi değildir).
Help with Freezing Nintendo 64
Hello, I have a nintendo 64 with the ram expander and after a random time, it freezes. I tried cleaning every cartridges and the cartridge slot but it keeps freezing. ( There is still music sometimes but the image is frozen )
Can someone help me ?
Thanks !
Bu iyi bir soru mu?
Puan 6
Yorum Ekle
3 Cevap
Filtre ölçütü:
Seçilen Çözüm
Is it an officially licensed Nintendo expansion pak? Way back when there were third party expansion paks that had a knack for heating issues and freezing problems. If it is Nintendo branded, then the RAM may be going bad. Switch it out for the original jumper RAM and see if the problem persists.
Bu yanıt yardımcı oldu mu?
Puan 8
1 Yorum:
Hello , It is not an official Nintendo RAM, I tried the original RAM (the black one)and i played 30 minutes without freezing. So i think the problem is solved.
Thank you !
tarafından
Yorum Ekle
Hey i had the same problem, luckily i had another expansion pak and swapped it and it works fine. It might be your jumper pak or expansion pak, try switching with another one.
Puan 0
Yorum Ekle
I have the same problem. I replaced the expansion pak by the jumper pak which came with the console. Freezes do not happen as often as with the expansion pak, but still happen every ten minutes. Any idea what I could do?
Thanks!
Puan 0
Yorum Ekle
Yanıtını ekle
Alexandre sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 13
Son 30 gün: 93
Her zaman: 34,263
