Ana içeriğe geç
16, 32 veya 64 GB depolama alanı seçenekleriyle sunulan, ikinci nesil Apple iPad'in Wi-Fi özellikli güncellenmiş versiyonu için onarım rehberleri, söküm ve sorun giderme bilgileri. Mart 2012'de piyasaya sürülmüştür. A1395 model numarası ve 2560 EMC numarasıyla tanımlanır. Daha küçük bir işlemci kalıbına ve güncellenmiş dahili yapıya sahiptir. Onarımlar, ısı kullanımı ve dikkatli bir şekilde ayırma işlemi gerektirir.
Looking for WiFi Antenna Part?
I note that iPad 2 Bluetooth/Wi-Fi Antenna says its not for the EMC 2560 model, but is there a suitable antenna available somewhere?
Replace the Bluetooth Wi-Fi antenna compatible with the A1395 EMC 2415, A1396, and A1397 model 2nd generation iPad tablet. Görseli
Ürün
$14.99
Bu iyi bir soru mu?
Puan 0
1 Yorum
So what's the verdict, does this one work? The post labeled as the answer is indeed AN answer but hardly a solution and leaves the issue annoyingly unresolved and in an ambiguous way. I indeed have an iPad EMC 2560 that I'm about to replace the logic board in and was going to grab the cheap & especially fragile parts for the numerous reasons to do so and not that I won't be able to complete my repair without it but now I'm just curious what is so different or incompatible about the EMC 2560's and what's the solution or reccomendation if one should happen to require a replacement antenna for this model. Thanks in advance.
tarafından
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
I think this is it: http://www.powerbookmedic.com/Wireless-3...
Bu yanıt yardımcı oldu mu?
Puan 1
1 Yorum:
Sorry but that one says its the 3G antenna not the Wi-Fi one ?
tarafından
Yorum Ekle
I've replaced hundreds of iPad 2 antennas and never worried about which model it was. The connection is the same on them all and the mounting is the same. There are no electronics to deal with, its all analog.
You should be good to go. I do remember seeing a couple iPad 2.5s with weird antennas. If you could post a pic of yours, I could tell you 100%
Puan 1
Yorum Ekle
Yanıtını ekle
Wayne Lavis sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 14
Her zaman: 509
