Ana içeriğe geç
Apple iPhone 5s, 10 Eylül 2013 tarihinde duyuruldu. Bu cihazın tamiri, daha önceki modellerinkiyle benzerdir; tornavida ve plastik açma araçları gerekir. GSM ya da CDMA olarak, 16, 32, 64 GB kapasiteli Gümüş, Altın ve Uzay Grisi renklerinde mevcuttur.
3530 Soru Tümünü görüntüle
Error 4013/ Red screen with blue screen
Hello guys,
I have a problem with my iphone 5s. The phone stays in a reboot loop. After i connected it with the iphone and try a recovery, it gives me error 4013. I tried 2 screens, changed the back camera, and tried the recovery without the screen plugged on the iphone.I also tried three different batteries. The original one, and two fake ones. I keep getting flashes of a blue and a red screen in the recovery process. I also tried two different systems with itunes and keep getting the same error, also changed the lightning cable.
I am out of options. Can someone help me?
Update (09/29/2016)
Could it be something else? Because I also read something about the u2/ic chip reheating.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 2
2 Yorum
if you are thinking of heating the u2/ic chip ...make sure u apply a little heating , becos last time i tried to heat it the phone ended up dead...
tarafından
The error is a hardware problem no solution for the error i am also try but not successed...
tarafından
Yorum Ekle
2 Cevap
Filtre ölçütü:
En Yararlı Yanıt
It sounds like a case of long screw damage.
https://www.youtube.com/watch?v=TzlsG1M1...
That video shows how to repair and diagnose it.
Bu yanıt yardımcı oldu mu?
Puan 3
2 Yorum:
i see in the video that she uses a lot of advanced equipment. Can this be done with simple hometools?
tarafından
Short answer: NO
tarafından
Yorum Ekle
try and restore without screws on the fones some times it works and make sure u use a good cable
Puan 0
2 Yorum:
Must I remove the logic board screws?
tarafından
yes all of them
tarafından
Yorum Ekle
Yanıtını ekle
Rachid El Bali sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 2
Her zaman: 10,913
