I've seen it done but don't recommended.
Reason why they don't just sell the digitizer(the glass).
But yes it only adhesive that you have to remove carefully.
If your removing a digitizer from a defect, water damage LCD make sure that the ribbon isn't damage or burned at the ribbons ends.
If they're good, then remove the adhesive carefully, do not damage the bottom of the digitizer(there's an invisible web to the naked eye). When removing the adhesive, I recommend not to remove all the adhesive from the glass.
Why because your going to compress it together and you need to know if your mounting it correct.
Forgot to mention use a x-acto blade #11.
Hope that helps. Good luck with that.
But if anyone know where just to get the digitizer(the glass). Let us know.
Bu yanıt yardımcı oldu mu?
Oy verildi
Geri al
Puan
0
İptal
Bu yoruma uygun yeri bulmak için bu konuyu kaydırın. Ardından, taşımak için "Bu yazıya yorum ekle"ye tıklayın.
