Ana içeriğe geç
0.622kg (1.4 lb) tablet with a 10.8 inch display and 3 position kickstand released by Microsoft on May 5, 2015. Model number: 1645.
LCD Connector is damaged, help!
Hey all,
The connector where the LCD plugs in on my surface 3 was damaged during a screen replacement. The issue is I dont know what the part is called or where to purchase a new one.
Please help me
Update (10/06/2016)
This is the connector in question. This is on the main logic board and the LCD flex plugs into it. The black piece that clamps down on the flex is gone and there is a missing pin.
Bu iyi bir soru mu?
Puan 0
4 Yorum
Is it on the LCD or the logic board?
tarafından
The connector on the board was damaged in case that wasnt clear.
tarafından
[image|907316]
tarafından
Mike check the update. Looks to be a internal 35 pin logic board LCD connector.
tarafından
Yorum Ekle
4 Cevap
Filtre ölçütü:
Seçilen Çözüm
Mike, if you can post a picture of damaged connector, it would be a big help to ifixit , I believe the connector is the mother board ribbon connector. Check the attached link and see if it is the motherboard connector, Good luck.
Microsoft Surface 3 Display Replacement
Update (10/06/2016)
Mike, Looks to be a internal 35 pin logic board LCD connector. Hope the link is what you want, you can also try a search yourself for (35 pin lcd connector)
https://www.aliexpress.com/item-img/20-P...
Bu yanıt yardımcı oldu mu?
Puan 1
1 Yorum:
Posted a picture below showing the connector.
tarafından
Yorum Ekle
Mine too damaged, are you sure it's 35 pin connector at AliExpress
Puan 0
Yorum Ekle
I don’t think the above connector from Aliexpress is correct. Looking into it it seems to use the same connector that is on the Samsung Galaxy Note 4 2014. It is actually a 70 pin connector not 35 because there are pins on both sides. You might be able to buy a replacement off eBay or Aliexpress.
Below is the link to the connector on Aliexpress.
FPC Connector From Aliexpress
Puan 0
Yorum Ekle
Did anyone ever get anywhere with this??
Puan 0
Yorum Ekle
Yanıtını ekle
Mike Smith sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 21
Her zaman: 2,148
