Will not drain or spin makes a buzzing sound
How do I fix this problem if I bypassed the lid switch and it still does nothing what is the problem
Bu iyi bir soru mu?
Bu iyi bir soru mu?
Dwayne, Kenmore 400 washer will not drain or spin makes a buzzing sound.
Possibly the water pump is seized/clogged/plugged, remove water pump and check pump for debri and remove blockage. Good luck
Bu yanıt yardımcı oldu mu?
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 20
Her zaman: 8,754
3 Yorum
Dwayne Ramon what is the proper model number of your wahser and where do you hear the buzzing? It will not spin if it does not drain. Problem could be your pump, your filter. kinked hoses and other things like the lid switch.
oldturkey03 tarafından
Kenmore 800
Buzzes but don't drain or wash lower buzzing
Ron Haas tarafından
@Ron Haas
What is the model number of the washer?
jayeff tarafından
