Ana içeriğe geç
Model M6497 or A1005 / 500, 600, 700, 800, or 900 MHz G3 processor
Video problem - installing shim
Newbie here. What instructions do I need to follow to try and install a shim before I get new logic board?
Bu iyi bir soru mu?
Puan -1
1 Yorum
Could you give a better description of why you want to install a shim?
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
It's not hard
you just dismantle until you get the bottom off.... then shim over the Square you'll see pressed in the foil opposite the optical drive. You can affix the shim to either the foil or the case.
In my experience sometimes flame works when/if shimming fails... all these "work arounds" are temporary life prolonging "fixes".
only reflowing or replacing the VGC is a long term fix... but due to the cost it's becoming less and less cost effective.
Remember to return and mark accepted the answer that best solves your problem.
Good luck,
N
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
Tim sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 9
Her zaman: 1,389
