No Wi-Fi network to connect to.
I cannot connect to the Wi-Fi network and the Wi-Fi name is not showing up on the Wi-Fi network list on my laptop. How can I connect to network?
Bu iyi bir soru mu?
Bu iyi bir soru mu?
Reset the router using the red reset button in the back of the device. Wait for a power reset and search for the device on the wireless network list. If that does not work verify that your router is ON and the Linksys logo is solidly lit. If you are far from the router, you might try moving closer to see if your device is out of the wireless network range. Using a computer attached to the router via a network cable, open the router's web-based setup page by entering myrouter.local or 192.168.1.1 and make sure that Broadcast SSID is ON.
Bu yanıt yardımcı oldu mu?
The question is wifi name is not only showing on your laptop or everywhere else. If it is not showing only on your laptop means there is some technical fault in your laptop network settings. What can you do just follow the steps given below to troubleshoot Linksys wifi router not working on your laptop:
In case none of your devices are finding wifi names, it means you have a problem in your Linksys router. In this case, you have to follow the instructions given below:
Son 24 Saat: 0
Son 7 gün: 33
Son 30 gün: 89
Her zaman: 10,020
