iPhone 6S Proximity Sensor not working after screen replacement
Hello,
I replaced the lcd screen on my iphone 6s. afte replacement the sensor doesnt work anymore. if i put the phone on my ear the screen become dark and stays dark until the caller ends the call. if i put it away from my ear the screen stays black until caller ends call. if press home button etc that doesnt help, screen stays black until call ends.
i changed the sensor (frontcam) etc and it doesnt work either.
anybody has an idea?
Thanks in advance.
Kind Regards
Joseph
Bu iyi bir soru mu?
15 Yorum
It's probably the screen at fault where the part of the glass that is for the proximity sensor (where the proximity sensor sits) is not made properly / for the sensor to work through the transparent tinted part of the glass.
Either it's a mounting issue or a bad quality replacement screen.
Ben tarafından
THank you for your response. Whats the solution? is it possible to get the screen working? e.g. scratching the screen and then mark it or anything else?
Transporter Dave tarafından
Hi,
Ben its right, I heard once that the proximiti sensor has to signal timming clear, I mean, , clear it, reset config onphone and try again...
Also if you miss screws or the chasis is bended could affect that.
Luis tarafından
This is a tricky one. I just did an iPhone 6S screen repair, and took the top assembly part with the front cam from the original screen with little to no force. I can remove it without damaging the proximity sensor like I used to (remember pulling the front cam assembly and seeing the prox sensor sitting there on the screen inside the plastic sensor holder? lol) with those things. After the repair, the phone no longer went off during a phone call and putting it by your ear. I've bought two replacement front cam assemblies with proximity sensor and nothing yet.
I test by leaving the phone open, and using a tester app. When I cover the sensor with my thumb it should go to a black screen, but it doesn't. I'm not sure what happened. No physical damage, two other replacement parts didn't fix it. Did I somehow mess up the board? Has this happened to anyone else? I feel bad for that happening to my clients phone :/ I've done this repair many times before with no problem.
Scott S tarafından
I have the same problem and didn't have a solution for it.
Kim tarafından
10 tane daha yorum göster
