Ana içeriğe geç
Boot to long, press c, press option, new hard drive
I bought a new HDD, formatted, insert an OS leopard retail, recognized, but the apple and the lines arounds continue etternally, anyone know another way to install, something wrong with the install, any help will be great, thanks in advance.
Powerbook G4 1,67 1GB ram, super drive, 17" high res.
Bu iyi bir soru mu?
Puan 1
1 Yorum
Also I pull out the HDD and still have the same issue.
tarafından
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
Get another Mac with a G4 processor and hook them together with a firewire cable. Start your machine up holding down the "T" key. Do the install from the second Mac.
Bu yanıt yardımcı oldu mu?
Puan 2
7 Yorum:
good answer +
tarafından
Excellent answer, I did, install, everything ok trhough fiewire, but when I start apple logo lines arounds but freeze, I think there is something wrong in motherboard, I have several RAM 512, I change, I proved in the other mac, work fine, so any other suggestion any tip, thanks in advance and specially to mayer.
tarafından
By the wy I pullout supper drive, I think is bad.
tarafından
Start up holding the Shift key down.
Run disk utilities in Target Mode (firewire)
tarafından
Nothing, after a while do the same, freeze, I did everything but never open OS.
tarafından
2 tane daha yorum göster
Yorum Ekle
Are you sure the hard drive was formatted correctly? Just a suggestion. PPC Macs must be formatted in the Apple Partition Map Scheme in order to boot. PPC Macs will not boot from a GUID Partition Map Scheme. You will be able to install your OS on the hard drive but it will not boot. When formatting your drive in Disk Utility select the Options button and then select Apple Partition Map.
Puan 0
Yorum Ekle
Yanıtını ekle
Sergio sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 5
Her zaman: 1,365
