Ana içeriğe geç
Searching or no service
Hi Guys.
OK got a 6 plus thats having a few issues which i'm trying to put right for a client.
She had a screen replacement from a so called reputable shop which in all honesty was a mess 3 times they tried & in the end put a broken screen on & refunded her saying the fault was with the body by the volume controls which where there was damage.
I replaced the screen for her & we tested it here she had full signal & was able to send & receive calls i also attempted to straighten out the damage to the body.
it was all working fine except for no sound from the main speaker on the phone which i said if she could pop back i would take a look at it for her.
Just so i can get this straight in my head the top left of the board the antenna there is the wifi & bluetooth & the GSM antenna is part of the lightning/headphone port with the connection just below the battery connector on the board i could be wrong I'm hoping someone will point me in the right direction if i am?
I'm suspecting the issue is down to the lightning port cable as it also has the speaker issue too.
What are your thoughts guys any help or suggestions would be greatly appreciated.
Thank you
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
1 Yorum:
I agree with Justin, test a new port.
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
It seems to me you're on the right track. Seeing as though you have speaker issues, the lightning port could be on its way out. I would try switching that out first to see if you have better luck with the cellular connection, as well as the loud speaker.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
Kenny Leonard sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 16
Her zaman: 199
