Ana içeriğe geç
Renault Mégane II olarak da bilinen 2. nesil Renault Mégane için tamir kılavuzları ve destek.
Why do warning lights stay on when engine is running
why do warning lights on dash stay on when engine is running
Bu iyi bir soru mu?
Puan 2
1 Yorum
Hi, Which warning lights are staying on?
tarafından
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
Norman, see the attached links for various warning lights and why they may be on. In some makes a lot of warning lights may come on and stay on when battery is faulty or charging system fault if both are tested and found to be good, you will have to have a good technician have a look, diagnose and estimate repair. Cluster or PCM could be faulty and not communicating correctly to one another. Check the attached links,instruction and guides, Good luck.
http://www.autozone.com/landing/page.jsp...
http://www.precisiontune.com/our-service...
https://www.theaa.com/breakdown-cover/ad...
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Last week I am visiting at http://universalmotorcarslv.com/ they guest are best
Puan 0
Yorum Ekle
Yanıtını ekle
norman rushton sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 3
Son 30 gün: 5
Her zaman: 1,662
