Ana içeriğe geç
Ocak 2014'te piyasaya sürülen Galaxy tablet lite varyasyonu. Samsung Galaxy Tab 3 Lite, hafif ve kullanımı kolay bir tablettir.
Is this power connector broken?
Hi all,
I am reparing a Galaxy Tab 3 lite 7.0 (T111/T113). I replaced the digitzer, so far so good, but when I turned the tablet on the lcd screen stayed white, while it was working allright before the replacement of the digitizer. I checked the connection of the lcd, cleaned it with isopropanol, but no result. The connector looks fine. Then I took a closer look at the power connector. The center pin seems to be different then the other 6 pins:
Resim
Resim
It is a bit hard to see but the middle pin is way shorter then the rest: did I break it? Or does it need to be shifted 'under' the power flex cable instead of above like the other 6 ones? I don't know for sure because the tablet powers on but the lcd stays white. The middle power pin says 'CNT' (as seen in the pictures).
Resim
Thanks in advance!
Update (10/12/2016)
@oldturkey03 Thanks for your answer! I actually removed the locking mechanism myself to make this picture but I already put it back in, no result. What do you think about the LCD cable?
Resim
Bu iyi bir soru mu?
Puan 1
5 Yorum
hard to see but even that looks ok. Have you tried hard reset?
tarafından
Hard reset with volume down, home button and power?
tarafından
Just tried hard reset with home+power and volume up and also volume down, but without result. Is it wise to order a new LCD or could the problem be somewhere else?
tarafından
A new LCD wont hurt and if nothig else it will verify that the fault is either the LCD if it works with a new one. If it does not you at leats will know you are having issues with the logicboard on this.
tarafından
Thank you very much! I actually went through all your information, everything was OK, but then, all the way at the end, I found out there was a tiny little cut in the lcd cable which wasn't visible because it was covered with a piece of tape. Bad luck I guess, but when I put in a new lcd everything was fine again. Thanks for your help!
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
@bartn "The connector looks fine." I do not think so. You are missing the locking mechanism to lock the cable in place. There is nothing that forces the pins to make proper contact with the cable. Take a look at what it is supposed to look like on the following image.
Resim
Update (10/12/2016)
@bartn see if this will help you further
Resim
Resim
Resim
Bu yanıt yardımcı oldu mu?
Puan 2
7 Yorum:
@oldturkey03 Thanks for your answer! I actually removed the locking mechanism myself to make this picture. When using the locking mechanism the screen also doesn't work.
[image|910792]
tarafından
@oldturkey03 But do the pins on the socket need to be 'over' or 'under' the flex cable? The contact patches of the flex cable are one the underside.
tarafından
The pin length looks ok
tarafından
Ow very nice, I just see the update now. Where did you get this information? I'm going to try it right now
tarafından
Is there a special way to remove that metal cover on those parts or can I just take it off? I replaced a lot of screens and so on but this is kinda new for me, but i want to try it.
tarafından
2 tane daha yorum göster
Yorum Ekle
Yanıtını ekle
Bart Nijenhuis sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 16
Her zaman: 798
