Ana içeriğe geç
Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
4994 Soru Tümünü görüntüle
iPhone 6 no sound
i have an iPhone 6 and one day i opened it to replace the battery after i start it up
i noticed that the iPhone has no sound at all when i open youtube app shows an error Playback Error , snapchat won't load videos instagram too and i pluged in the headphones and the sound work perfect when i connect with a bluetooth speaker the sound work perfect too. i tried to change the speaker change the chargning port but no luck. i have more .. when the phone is on and i plug the headphones don't show me the volume HEADPHONES but Ringer so i have to reboot my device to activate the headphone mode
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
En Yararlı Yanıt
My guess is you broke the power/volume flex when removing the battery. Did you have to use pry tools to change the battery or did you use the pull tabs?
Bu yanıt yardımcı oldu mu?
Puan 1
2 Yorum:
no i know how to remove the battery just by pulling out the glue under it but it's not the problem there i have replacet the motherboard (my motherboard) into another iphone 6 (works very well) but my motherboard still do not support sound in any speakers
tarafından
Good. I'd still try a new volume flex. Its a good starting point.
tarafından
Yorum Ekle
Hello. In my opinion it's not volume flex damaged. But ive got questions for You :
1) Does your phone getting lag when trying to rec a video, or trying to watch any video with sound on YT
2) Does Phone lag while some1 calling you, when you have sounds turn on , and does he works properly when you have sounds off ?
When phone works properly on headphones You could have damaged sound IC, it's very expensive in repair, and very dangerous, beacause its "under" screen connections on Mainboard.
Puan 0
Yorum Ekle
Yanıtını ekle
Adrian Zymeri sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 2
Her zaman: 258
