Why is the water draining and filling at the same time?
The water is filling thru the detergent hole and very slowly but at the same time its draining so it never fills up.
Bu iyi bir soru mu?
Bu iyi bir soru mu?
The water inlet valve on your washing machine is used to fill the tub with cold, warm or hot water for the wash and rinse cycles. The valve is operated by electric solenoids that are controlled by the timer or electronic control board and the water level control/water level selector switch or pressure switch. If your washer continues to fill during a drain cycle, the water inlet valve could be at fault. To verify that the valve is at fault, unplug the washer when the symptom occurs. If the washer continues to fill, then the inlet valve is defective. If the washer stops filling, then the problem is related to the electrical circuit that controls the valve.
The water level switch is a pressure activated switch that is used to determine the correct water level in the tub. This part is normally located behind the control panel and will have a hose or air dome tube that connects it to the tub. On washers that use an electronic control, this switch may be located at the sump area below the tub. As the water fills in the tub it will compress the air in the tube and push against a diaphragm inside the switch. The switch will control the water inlet valve and turn the valve off at the correct water level. If the tube has a leak, not enough pressure may be created to activate the switch and the washer may overfill. If the switch is defective it may also cause the machine to overfill. To determine if the switch is bad, you should first eliminate the air dome hose as a problem. Look for signs of cracks or worn areas on the hose. Remove the hose and submerge in water. Seal one end and blow air into the other end and look for bubbles. Check for an obstruction in the hose as well. If the air dome hose appears to be ok, then the water level switch may be defective.
Bu yanıt yardımcı oldu mu?
Why won't my washer wash it fills makes noise like it's washing but is not washing
@Robert Dean it could be the agitator is worn where it attaches to the drive shaft. There should be a screw to remove and the agitator will lift up. Look in the bottom of agitator and see it the groves are worn. Also look at the drive shaft for wear. With the little info you provided, that’s the best I can suggest.
Filling and draining at the same time means it’s syphoning out the water due to the drain hose being too far down in the stand pipe/drain pipe behind the washer. The drain hose can’t go below 32” from the floor without an air break or it will syphon out the water. Pull the drain hose out of the drain pipe then put about 6” back in it and secure it with zip ties etc… so it won’t come out or go in further down.
Wish I had seen this before spending my day off figuring out the diagnostic mode and codes and blah blah blah.
LOL......live and learn, right?!
Thanks! I have clean clothes now! :)
Son 24 Saat: 5
Son 7 gün: 27
Son 30 gün: 105
Her zaman: 5,664
2 Yorum
Hi my washer is filling up not washing then draining again please help me with this
Robert Dean tarafından
The Samsung self-cleaning washer is filling but not washing and draining why okay
