Ana içeriğe geç
Apple released the slimmed-down, buffed up iPad Air on November 1, 2013 in a choice of Space Gray or Silver. It packs the custom A7 processor and ships in 16, 32, 64, and 128 GB configurations.
Battery will not charge past 1%
My ipad air only charges to 1%. The battery is flat and when I attached the lightening cable it will make the icon of the cable disappear and show a battery in the middle of the screen that appears to be charging. The ipad gets to 1% and turns itself on but that is as high as it gets. Eventually the screen goes black again and the ipad does not recognise that the cable is still attached. If I remove the cable from the wall charger and put it into the USB on my laptop the whole process begins again until I change it back to the wall charger. I have tried different cables and chargers, some Apple and some not. I initially replaced the charge port as it seemed that was the issue because I could wriggle the cable and get the ipad to show charging. I have checked the soldering and it all appears fine. I Have tried the reset method and leaving the charger attached all night but nothing changes. I am beginning to think the problem may have been the U2 chip all along. Does anyone else think that is a fair assessment or is there something else I should be looking at?
Bu iyi bir soru mu?
Puan 4
7 Yorum
Does the laptop charge on the laptop, or the wall charger? The current in the laptop or wall charger may be too weak for the ipad to charge. An iPad requires 2.4A to charge, while an iPhone needs 1A.
tarafından
The wall charger is an Apple 2.4a and 5.2v output.
tarafından
I’ve used apple charger and others still remains at one. %
tarafından
Same here on an ipad just bought in June, problem started nearly 4 weeks later, have bought numerous charges and plugs since, all from apple, feel ripped of. So clearly this is a common problem and should be apples responsibility.. more life in a golden delicious atm that this junk!
tarafından
Same. No charger is charging it beyond 1%.
tarafından
2 tane daha yorum göster
Yorum Ekle
11 Cevap
Filtre ölçütü:
Seçilen Çözüm
It sounds like you're charging your iPad using an adapter or power source that is too weak. I would suggest using the original (or a certified for iPad) adapter and seeing if that improves the results.
If that's ruled out as a potential issue my next best suggestion is to replace the charging port and/or battery.
iPad Air, iPad 5, iPad 6 Battery
iPad Air Lightning Connector
Best of luck!
Replace a corroded or damaged lightning connector in your 1st generation iPad Air model A1474 and A1475. Fix problems with charging and connecting to USB devices. Görseli
Ürün
$19.99
Replace a 8827 mAh battery compatible with a 1st Generation iPad Air, iPad 5, and iPad 6.
3.73 Volts (V). Görseli
Ürün
$49.99
Bu yanıt yardımcı oldu mu?
Puan 2
3 Yorum:
Matt, I have been using the charger supplied, still no luck. We have tried numerous other ipad plugs an cables which we got with ipods iPhone etc, will turn ipad on on charge an then stop charging at 1%.
tarafından
I had the same issue went to apple and best buy they said its toast and then took to a small repair shop apparently the connector from the charging port to the battery got bad… so they replaced the wire and its all good now
tarafından
What was the cost?
tarafından
Yorum Ekle
En Yararlı Yanıt
I performed a hard reset - held the power and home buttons down until a black screen appeared with a white tablet and cable - and left it alone, just keeping it plugged in to the wall charger.
THAT screen stayed up about 5 minutes, then rebooted to the white screen with the black apple, the the login screen came up. It had kept the hard reset screen up long enough to bring the battery up to 6%, so I could shut it down to charge all the way.
Ridiculous issue to begin with, but that's what finally worked for me.
Puan 3
6 Yorum:
I don't know if this is going to work--still downloading software--but at least I got to the irestore screen! Thanks.
tarafından
This is what did it for me - hard reset.
tarafından
Nothing worked for me, my iPad would not charge beyond 1% and no reset would fix the problem. I decided to follow an advice I came upon and bought a usb-c 30W charger and that did it! Now I can charge it fully. The original charger stopped working – for some reason now it became too weak at 15W. Technical service even wanted to charge me a lot to swipe something in the motherboard, but I’m glad I was able to avoid it. Please try this when everything else seems not to work.
tarafından
I aIready tried the new charger on my ipad which was a 35w and that has not worked either. Bought new charger wires, charger and did hard reset and nothing worked. It sounds like everyone has a different solution maybe to use but everyone still has a problem with the ipad not charging over 1% and keeps shifting down in few seconds. It's so RIDICULOUS. I paid so much money for this iPad and all it's doing is giving me a problem after 3 years. Never again!
tarafından
how to fixn it plzzzzzzzzzzzzzzzzzzzzz
tarafından
1 tane daha yorum göster
Yorum Ekle
It's an apple product, it's designed and manufactured using an “engineered obsolescence” model of development. Ever notice how older iphones and iPads get really glitchy when a new model is released? I have.
My advice…trash it and get something running
Puan 0
2 Yorum:
thats because tech gets better and software keeps requiring more and more power, and are we gonna ignore that apple products last longer than any of the competition
tarafından
Seen something posted before from an ex employee that each device is only manufactured to last about 18months or so so that you upgrade to newer version before contract is up
tarafından
Yorum Ekle
I have the same problem and use the original charger that came with the device.
Puan 0
Yorum Ekle
Had the same problem. SOLVED IT! Just buy fast charger 20W and the cable for it. Few minutes of charging made the job for me! Good luck!
Puan 0
Yorum Ekle
Same problem I'm facing with..
My ipad is not charging beyond 1%..
After 1% the charge icon disappears and stops charging..
Similar thing happend to my iphone also 2years back.
That time they replaced with new phone.
But now my ipad is not in warranty. Seems like Apple phones are engineered to cause issues like this.
Any genuine solution to this?
Puan 0
1 Yorum:
Yeah! I have fix it.
Bought fast charger 30W.
Hard reset your iphone/ipad and when it beg for a cable - press and hold the button meanwhile plugging in.
Hope it will work for you too!
Good luck!
tarafından
Yorum Ekle
I couldn’t get to the settings menu until I plugged it into my car charger because it wouldn’t stay on long enough. For some reason it stayed on longer on the car charger. So once I did get it to stay on I put it in airplane mode and turned off all power draws such as Bluetooth, WiFi.
Plug into a charger that puts out the correct voltage and it will charge if the battery or plug port are not defective. Within 10 minutes it is at 7%. Give it a try.
Puan 0
Yorum Ekle
Same problem experienced, charger changed, tried reset, no joy.
Cleaned out the charging port with IPA solvent and toothbrush (showed signs of some arcing may have occurred), still wouldn’t charge though apple logo would come up and home page but no charge symbol in battery.
Decided to spray charge port with IPA and long soak, approx 1 hour.
Result, charging away quite happily.
If it works for you too then suggest remove USB from plug first iPad last.
Puan 0
Yorum Ekle
Mines on a continuous loop, dead, charges to one, dies again. I just fixed to port today because it stopped charging so it’s a fresh port. Any help???
Puan 0
1 Yorum:
20W charger does the job. Leave it overnight.
tarafından
Yorum Ekle
could i be the battery
Puan 0
Yorum Ekle
I have the same problem. only way I can charge it is using a 12 watt power bank. When it is totally empty and I connect it to a wallcharger it will charge to 1% and if I do not touch it sometimes it charger to 100% (depending on the charger I use, 20w usb-c never past 1%, 15 watt usb-a charger sometime to 100 if the iPad is not disturbed.).
at least I can charge it sing the power bank and it is not totally bricked but my search for a wallcharger that works continues.
hope this can help.
Puan 0
Yorum Ekle
Yanıtını ekle
Paul Le Roy sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 52
Son 7 gün: 515
Son 30 gün: 1,940
Her zaman: 112,921
