Ana içeriğe geç
Get rid of touch and hold gesture
When I have the file explorer active and I touch and hold on the trackpad (mouse) the wheel comes up with options "home", "end", "back", and "forward". I cannot even get the thing to work. I'm just trying to turn it off.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
1 Yorum
I have a Noteook 9 and have this same issue. This icon randomly shows up and I have tried all the suggestions in this post and none have worked. I have also talked to Samsung Tech Dept and they have 'never heard of this problem'...which I find hard to believe. Has anyone been able to get rid of this icon on their Samsung Notebook 9? Thank you.
tarafından
Yorum Ekle
3 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Hopefully this will help others because this "feature" is so annoying that I was seriously thinking about exploring new laptop options and returning this otherwise wonderful Notebook 7. I had looked everywhere possible in the traditional Windows settings. This feature is a HUGE nuisance IMHO as it was causing me to constantly skip in and out of my work areas.
This solution will still allow you to utilize all of the wonderful multi-touch gestures and disable only this one setting.
To disable this:
Start up the Samsung Settings App
Go to the Input menu option
Turn off "Press & Go"
Bu yanıt yardımcı oldu mu?
Puan 5
6 Yorum:
oh gosh, thank you so much for sharing this. This feature was driving me nuts and I was about to crush my laptop into pieces. I wonder what kind of an idiot thought this was cool and decided to add this feature.
tarafından
Many thanks, the option to switch it off is so well hidden that it would be virtally impossible to find without help.
tarafından
Thank you for saving my life.
tarafından
Thank you so much, you've kept me from going insane!
tarafından
I can't tell you how much I appreciated this post!! Thank you.
tarafından
1 tane daha yorum göster
Yorum Ekle
I believe this Notebook pc has Synaptics Pointing Device,
1. Type in search "Synaptics Pointing Device" and click on that entry
  • If that doesn't show go to "Control panel" and click on "Mouse Properties"
2. A Window will pop up for the Drive, In the Menu Tabs you should see "Device Options" with a -Red Logo-
  • select that option and settings for that specific driver will show, Click on "Settings" under the pointer device selection, Now you can Modify how and which gestures perform and to Disable them or not.
Screenshot posted:
Puan 4
3 Yorum:
Thanks for the quick response but I cannot seem to find ether of those options. =(
tarafından
what OS are you running? The specs I looked up said windows 8.1 upgradeable to windows 10.
tarafından
Thank you. It was hard to find, but it worked.
tarafından
Yorum Ekle
To make the wheel go away, touch the pad and don't move for about one second.
Puan 2
Yorum Ekle
Yanıtını ekle
Tony sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 11
Son 30 gün: 22
Her zaman: 6,539
