Why is my speaker not turning on?
I press on the power button for 5-10 seconds but there is a delay in starting up.
Bu iyi bir soru mu?
Bu iyi bir soru mu?
This is normal. After powering your speaker, it takes 1 minute to start up. The power sensor light will flash red and blue. Once it stays solid blue your speaker is ready to be used.
Bu yanıt yardımcı oldu mu?
My power button stays solid red even after I tough it. Unit does not power up.
i have the same issues, how its solve the problem?
please do you know how to fix it when it's stell going blinking red and blue whithout turning in solid blue??thanks
monster 4 was made from china maybe, it isn't good, mine bad, no power now
I saw a YouTube video where a guy has this EXACT ISSUE. He said it never turns on. He presses it, uses entire hand at times….found that sometime using his PALM WORKED! Funny…but irritating considering an expensive speaker has this glitch. Then he said, even his palm stopped working. He ended up taking a butter knife to the (when facing the speaker) right side. Use the knife to gently lift up the top plastic cover until you expose the red light section of the ON button. Use your finger NOW and place it over the sensor.
It should turn BLUE I'm a few seconds.
Then gently place the black cover piece back down .
Worked for me. Irritating, considering this is NOT a $25 speaker. This detailed for over $200 when it first came out.
Grrrr.
Try that. Or watch his video ….
Best luck!
Won't power up. I plugged it in and nothing
I am connected by Bluetooth but no sound coming out of superstar Monster blaster
Answer please
My monster bluetooth speaker turns on but won't Play right away
Son 24 Saat: 5
Son 7 gün: 47
Son 30 gün: 185
Her zaman: 22,104
7 Yorum
I was told it's the circuit board is bad and can't be replaced
These things are junk,
Todd
TODD STEFFEN tarafından
I stumbled across a hack, try this...
1) plug in speaker
2) plug in micro usb into back of speaker ( I connected mine to PC usb port )
3) power up speaker ( this time it boots up )
This fixed my issue of when I hit the power button the blue light would blink once then the 4 blue LEDs would light up on the front and then power light back to orange and nothing.
stephan.mackenzie tarafından
Did this and its still blinking, its been over ten mins. How long does it blink for?
Drew's Prestige Customizing tarafından
lilidoum tarafından
Monster earbuds will not power up, used them 3 times why is this happening?
Woody tarafından
2 tane daha yorum göster
