Ana içeriğe geç
The Nissan Altima is a mid-size automobile manufactured by Nissan, and is arguably a continuation of the Nissan Bluebird line, which began in 1957.
Why does it do this?
I have a 2003 Nissan Altima, when I crank the car up and put it in drive it stars running bad or might go dead. So I crank it back up and put it in first and start off and put it straight to drive it runs fine, doesn't run hot or anything, but if I stop at a stop sign it'll start running bad again and have to repeat the same step, from first straight to drive, any idea what this might be?
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
@hutch6 not sure where you are but I would get the OBD scanned to see if it throws any codes. Sounds like it is coming from the transmission.
Rep: 1
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
En Yararlı Yanıt
Shane, This could be caused by a few things. It sounds like your transmission torque converter lock up/solenoid may be malfunctioning/sticking. Take into a good shop, have them scan for trouble codes, diagnose and estimate repair. Good luck.
Puan 2
Yorum Ekle
Yanıtını ekle
Shane hutcherson sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 4
Her zaman: 138
