Ana içeriğe geç
A Vivobook series produced by ASUS in 2012. The Q200E series is similar to the S200E and X202E series.
Why wouldn’t my laptop power on?
My laptop is not powering on even after holding the power button. How do I power it on?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
1 Yorum
student, iFixit Technical Writing Project
tarafından
Yorum Ekle
2 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Make sure your battery is charged by starting your laptop with the charger plugged in. If that does not work, you can also try following our troubleshooting guide.
Bu yanıt yardımcı oldu mu?
Puan 1
1 Yorum:
Will disconnecting the battery from the logic board and disconnecting the power supply cause a spontaneous reboot when the battery is plugged back in?
tarafından
Yorum Ekle
First i would check if it is plugged in, then also if the battery is charged. when you have both the adapter and the battery connected then you should be getting a charging light even if the laptop is off. The first thing i would question would be the power adapter and then go from there. good luck
Puan 0
Yorum Ekle
Yanıtını ekle
Laura Clutterham sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 5
Son 30 gün: 6
Her zaman: 183
