iPhone 6S Glass Only Repair Big Bubbles after Lamination Machine HELP
I have been doing glass only repair on iphone 6. My success rate on iphone 6 is about 95%. On the iPhone 6S, I follow all the same steps and once lcd comes out of the Oca laminator machine , there are Huge bubbles witch are hard to remove on the AutoClave. I have to put them on Autoclave for a very long time witch later on cause for very small bubbles to appear on the corners of lcd( since OCA has been cooking for a long time). Im trying to find out if anyone else have problems like this. Maybe my machine is not right for this. I am even willing to buy a new oca laminator machine that does them correctly.
Please comment on the machine you are using if you are getting good results on your glass only repair , or comment if i should be doing something different on the iphone 6s compare to the iphone 6.
below are the steps I take
- remove broken glass
-remove polarizer
- clean
-intall new polarizer
-add antistatic paste
-use OEM glass & Mitsubishi OCA
-put on "KO no.1 Laminator Machine" 2 minutes vacuum time & 4 minutes laminating time. ( i have tried all type of setting here and still have very mix but not good results.
I have also tried messing with the psi pressure
- SO the problem is the Huge Bubbles ( not little ones ) once coming out of the KO OCA Laminator machine.
thank you in advance
Bu iyi bir soru mu?
i have the same problem only with iphone 6s after place oca sems all good after instaloing glass small bubbels apair in the corner i dont know why
Florenc Shehu tarafından
Hi guys has any body found solution yet for this problem? I am experiencing Same
mohammed patel tarafından
