@keenq05 , check warranty, if still under warranty return for repair/replacement. If out of warranty. The charge port in question is the USB type which is probably soldered onto the board so hot gluing probably would not be effective. If not comfortable fine soldering, a cell phone or computer repair shop could probably manage the repair fairly easily. Have a tech. take a look and estimate repair. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
UPDATE: for @frampgirl12, Look in the charge port and blow/pick out(carefully) any dust/debri that may be causing an issue also look in the port for any bent pins and straighten very carefully with a tooth pick. If port is found to be bad/loose/damaged , this is really not a repair for the inexperienced because the charge port for your device is soldered to the mother board and the heat generated could cause further damage if not very careful. I will post a link to a tear down guide to get you inside the tablet to check the charge port and will also post a link showing what is involved in repairing a mini USB attached to the board. You can also do a search for a replacement charge port using make and model or match it visually perhaps with one from a seller online.
Infant Optics DXR-8 Back Cover Prerequisite
https://www.youtube.com/watch?v=rTim6FIJ...
http://www.ebay.com/bhp/micro-usb-port
Bu yanıt yardımcı oldu mu?
Oy verildi
Geri al
Puan
5
