Ana içeriğe geç
iPad Mini 4— A1538 modelinin Wi-Fi versiyonu için kılavuzlar. 9 Eylül 2015'te duyurulan iPad Mini 4, iPad Mini 3 modelinin yenisidir.
97 Soru Tümünü görüntüle
Replaced lcd digitizer, now screen flashes and wont stay on.
I replaced a cracked lcd digitizer. Now when I hit the home or power button, the screen lights up and I can see everything for a split second, then everything goes black again. It's still on and for that split second everything looks as it should. I've tried disconnecting and reconnecting the flex cables and the battery flex cable, same thing. Everything is snug and seems as it should be. I'm hoping I didn't damage any of the gold connectors. Any ideas?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 3
1 Yorum:
if you didnt unplug ipad battery before repair you may have also damaged the backlight component. if new screen doesnt fix the problem you will need to find someone who repairs the boards.
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
Hi
Try to check the LCD connector with a magnifier. (with a microscope would be better indeed).
Also try to make a magnified photo if possible.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
Jeff Ray sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 7
Her zaman: 819
