Ana içeriğe geç
Touch IC or connector or both?
Got a 6 plus that is like this, does it need new touch ic or connector?
touch is bad so that needs doing and grey bars at top
the screen is fine, i just want to make sure the phone will display fine if touch IC is fixed
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
If you're getting grey bars at the top 100% touch ic guaranteed. I also noticed your top right backlight is dim. If it's still this way after swapping the touch ic you need to replace part of the backlight circuit as well.
Bu yanıt yardımcı oldu mu?
Puan 1
3 Yorum:
that's what im talking about
tarafından
You know on the top right that is usually either LCD connector on logic board or LCD ribbon cable needs to be pushed in more.
tarafından
it can happen in either corner i have it on a 6 but not sure if it is, it only happened on the 6 because i test screens constantly so it got damaged. the connector looks fine to me
tarafından
Yorum Ekle
Yanıtını ekle
David F sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 3
Her zaman: 129
