Ana içeriğe geç
Panasonic's phone model first released in 2007 with features such as voice mail, caller ID, call waiting, call transfer and call hold. Model number: KX-TG6021M
Why is my signal so bad?
When I'm a certain distance away from the charging base, my call sometimes drops.
Bu iyi bir soru mu?
Puan 2
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
Hi,
Sometimes bad signals can be cause by interferences in your home. To fix this issue you can make sure that your charging base is placed at a higher point in your home to insure less resistance for the signal. Also you can check your antenna to make sure it is working correctly and if not refer to the replacement guide to replace it.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
You may need to get closer to the charging base. Also, make sure walls or other objects are not impeding the signal from the phone to the charging base.
Puan 0
Yorum Ekle
Yanıtını ekle
You Zhou sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 3
Her zaman: 234
