Why is WIFI will not turn on?
I cannot turn on WIFI switch.
Bu iyi bir soru mu?
Several Reasons behind on this, just like :-
If you are using an android smartphone, it may sometimes won’t turn on for several reasons.
The most common reason could be low memory space in your device.
Check the RAM manager and see if the free memory is less than 45 MB. If it is, the Wi-Fi won’t turn on normally.
The other reason may be the fact that power saving mode is on.
Solution of “Wi-Fi won’t turn on” problem
Clear memory
Reboot The Phone
Turn WIFI Power Saving Mode Off
Check Airplane mode
Update Firmware and Change Channel of Router
Disconnect All Devices
Check The Third Party Apps
Perform A Factory Reset
How to turn on or off Wi-Fi in Android
There are times when you might want to turn off the wireless connectivity option on your Android device or to turn it on. This is a very simple process and is done in just two to three easy steps. On Android, you are first required to:
How to turn on or off Wi-Fi in iOS
The process of turning Wi-Fi on and off on any iOS devices such as iPhone, iPad or iPod is more or less similar to the process on Android one. This is also a small tap on the option and that’s it.
What you need to do is head towards settings and then tap on Wi-Fi. Slide the Wi-Fi option to turn it off and on.
How to turn on or off Wi-Fi in Windows
Windows also comes with the option to enable or disable wireless connectivity in need but the process differs a bit compared to Android and iOS devices. It is explained here:
First, go to the start menu after which you are required to look for the Control Panel.
Once you find, tap on it.
Next tap on the ‘Network & Internet category’.
Choose the option Networking and Sharing center option from there.
It will bring you several options on the left-hand side. Click on the ‘Change adapter settings’ option.
Next,right-click on the wireless connection icon and it will get enabled.
Follow the same steps if you want to disable it.
Bu yanıt yardımcı oldu mu?
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 3
Her zaman: 642
