Ana içeriğe geç
Model A1419 / EMC 2806 / Late 2014 or Mid 2015. 3.3 or 3.5 GHz Core i5 or 4.0 GHz Core i7 (ID iMac15,1); EMC 2834 late 2015 / 3.3 or 3.5 GHz Core i5 or 4.0 GHz Core i7 (iMac17,1) All with Retina 5K displays
573 Soru Tümünü görüntüle
Can you remove the VESA mount from a late 2015 Retina iMac
I have a late 2015 model Retina iMac with a 27 inch display. The iMac was purchased direct from Apple with a VESA mount pre-installed. The mount is secured to the iMac with two pentalobe screws. Does anybody know what size pentalobe screw's are used on this model iMac?
Image of VESA bracket
EDIT, 02/11/16 @ 16:36
I have a desk mount which is designed to attach to an iMac both with and without the VESA bracket installed. Without the VESA bracket is a much neater solution because the mount attaches directly to the metal bar which the VESA bracket would normally be secured to. Officially this mode only works with pre-2012 iMac’s where the desk stand could be removed; however I see no reason why I couldn’t remove the VESA bracket installed by Apple and attach the desk mount. That is unless there are additional screws which are not accessible from the outside of the iMac.
Bu iyi bir soru mu?
Puan 2
Yorum Ekle
3 Cevap
Filtre ölçütü:
Seçilen Çözüm
The bracket piece is needed! And it needs to be a VESA mount. I have not seen any desk mounts that worked without a VESA mount or without the complete foot assembly present on the system for any of the newer 'Thin Series' iMac's.
I suspect the CodyTech mount is similar to the NuMount Pivot Desk Mount which is described here: NewerTech - NuMount Pivot Desk Mount. If you download the PDF you'll see they have a custom piece that replaces the foot like Apples VESA mount but offers a smaller profile. As you don't have the same mounting as the older iMac's and the piece that you do have on your system now is not going to allow you to mount the CodyTech unit as the screw alignment and height are different. Again, remember this was for the older models not this series.
Here's the VESA mount we had used on some of our older systems
You might want to reach out and talk with them to see if having just the tail piece installed if there is a way to get it to work otherwise you'll need to try it your self.
Here is the special frame to connect to VESA by mounting via the cable hole in the foot: VIVO STAND-MACB VESA adapter for iMac.
The other option which some people have done is to drill & tap the foot to mount the VESA unit. Here's a YouTube vid: 21.5" Wall Mount.
In any case I wouldn't try replacing the VESA with a standard foot just to then use an adapter to remount it via a VESA mount that would be a waste.
Bu yanıt yardımcı oldu mu?
Puan 2
1 Yorum:
Thanks Dan. You are correct, the Cotytech mount can be attached directly to the iMac just like the NewerTech mount. From what you've said I gather that even if I could remove the VESA adapter from the Retina 5K iMac it wouldn't matter because the alignment of the screw holes on the mounting bar is different to those found on older iMac models. Cool, that's all I needed to know. It also looks like the pentalobe screws are significantly larger than the ones used on the MacBook Pro's. I don't think anybody makes a commercially available screwdriver that would fit these screws.
tarafından
Yorum Ekle
You can get the tools at iFixIt store
https://www.ifixit.com/Store/Tools/all?f...
Puan 1
4 Yorum:
Can you confirm the P5 Pentalobe is the same screw type used in the 2015 Retina iMac? According to iFixit the screwdriver is only for use on the MacBook Air and all MacBook Pro with Retina Display's.
tarafından
I have the following tool kit
Mako Driver Kit - 64 Precision Bits
There you get the P2, P5 and P6.
But I do not know how big the screw are one the Retina iMac.
tarafından
Cheers. Is there a set containing all the different sized Pentalobe heads? I'll buy that and then see what fits. God bless Apple and their non-standard screws.
tarafından
I bought this one where P2,P5 and P6 are included
Pro Tech Toolkit
Have not seen any other sizes but my Apple knowledge is not that deep but I have been able to open iphones and Macbook with the screwdrivers.
tarafından
Yorum Ekle
Not without a complete teardown. You could have ordered it with it,
@danj knows more about this than I do, maybe he will jump in here.
Please see this answer: Is the stand removable?
and
iMac 5K VESA mount to standard stand
Puan 1
Yorum Ekle
Yanıtını ekle
Kieran Butcher sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 15
Son 30 gün: 72
Her zaman: 10,132
