Why doesn't my shredder turn on?
When I try to use my shredder it won't turn on. I have it plugged in but it just doesn't want to work.
Bu iyi bir soru mu?
Bu iyi bir soru mu?
Lack of power to the Fellowes T7CM device can be a result of different issues. Prior to proceeding, check to make sure that the power cord is properly inserted into the wall outlet. Also, check to make sure the device switch is properly placed in the "ON" position. If the device is properly plugged in and the switch is in its proper place, try powering on another device from the same outlet. Check to make sure the power cord is securely fastened to the device as well. For further troubleshooting information, refer to the troubleshooting guide.
Bu yanıt yardımcı oldu mu?
Son 24 Saat: 11
Son 7 gün: 14
Son 30 gün: 32
Her zaman: 7,551
