home screen keeps flashing "ALCATEL ONETOUCH powered by Android.
Phone will not let me turn it off, on, or reset it. Just keeps flashing on main screen
Bu iyi bir soru mu?
Bu iyi bir soru mu?
@margiequail , Margie, Try removing the battery/unplug from your cell phone for 30 seconds, reinsert the battery, assemble phone, see if it will power on properly. If still not powering on properyl you may have to do a Hard reset. Link below will tell you how to remove battery, click on 2nd link for more models if yours differ.for battery removal. 3rd link gives more info. on trouble shooting your device and how to do a hard reset. Good luck.
Bu yanıt yardımcı oldu mu?
i got the same problem but my alcatel doesnt have a battery
Timyia, if you have a ALCATEL ONETOUCH it will have a battery, if no battery it for sure can not work. See the link below on how to change your battery and you can google your specific model # for a replacement battery. If you need more information post all your phones information and complete question, so ifixit volunteers can answer your question effectively. Have a good day.
Having the same or similar issue wen I press power button it blink on then off. It does not have a removable battery
This phone has a built in battery, i suspect this issue is a firmware issue.
Acaltel has bricked the phone so you can buy new one.
Bricked the phone? what does that mean?
Son 24 Saat: 2
Son 7 gün: 31
Son 30 gün: 118
Her zaman: 39,469
5 Yorum
That also is my problem with my Alcatel. This is what I did, when this occur I just press the volume up and down and the power button at the same time for 20 seconds more or less then release and press right again every second until the flashing stops and power goes off. then after a few seconds press the power to put it on. if it don't work do it again.
ernest0911 tarafından
No this is a tablet you can't get to the battery
David Walker tarafından
Is there a way to do it with a Alcatel tablet 4 7
bored person tarafından
Enjoy.now is the essential app for Alcatel smartphone users.
notes for if doing update
After update phone asks to do restart
Let it
When it comes back on it shows
enjoy.now flashing
Leave it flash till it natural goes into power down mode
Leave for another 5 minutes
Then power on as normal and all should be ok
It was on mine
v.stanley tarafından
If you leave it to flash it eventually goes to factory reset mode. Use volume button to agree to reset (you need an other WiFi to rcover your data) ofr it will reset from scratch
terry55bakerqo tarafından
