Ana içeriğe geç
The TomTom Go 60 S, manufactured by Tom Tom and released on March 1, 2014, is a portable GPS device with 6.0" touch screen and lifetime map updates for North America.
5 Soru Tümünü görüntüle
My device is not making any sounds?
I have turned on the volume to the highest level, yet I still can't hear anything.
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
First, try resetting your device by pressing and holding the On/Off button. Make sure the device has been charged for at least two hours before doing this. The device should make a drum sound when it turns back on.
Second, if the sound still doesn't work, go to the "Change preferences" menu to check if the sound setting is turned on. It should say "Turn off sound" if the sound is on.
If you did all of these and the device is still not making sounds, you may need to reinstall its software.
Bu yanıt yardımcı oldu mu?
Puan 0
1 Yorum:
Hi, i got the same problem…i dit all that , ive even reinstall the software like you said but still no sound.
Must be an hardware problem then !
tarafından
Yorum Ekle
Yanıtını ekle
Ambermarie Dawdy sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 16
Son 30 gün: 83
Her zaman: 281
