Why does my tablet lose charge so fast?
I charge my device to full every time, yet it loses all of its charge in less than two hours of reading. What can I do to fix this? What could be the problem here?
Bu iyi bir soru mu?
Bu iyi bir soru mu?
This could be caused by several problems and the issue could either be with the battery, charger, or simply how many programs you running. If you are using bluetooth or wifi in the background and do not need them try turning those off. Also if you have your screen brightness turned up high try lowering that as well because it could be draining extra battery. Lastly try and close any background applications that you don't need to be running.
If you have tried this and still have a problem then it could be a problem with the charger or battery. I recommend using the official charging cable if you aren't already and if you have a spare try charging with that cable.
As a last resort the problem could be that your battery isn't working properly and will have to be replaced. Avoid overcharging the device and also try not to let the battery life drop all the way down before recharging. It is optimal to keep the battery life at 60-80%. Try that for a couple of days and if you still have trouble then the battery most likely needs to be replaced.
Bu yanıt yardımcı oldu mu?
My little sisters table is doing this so ty from this information I will try it
If your WIFI is on the battery runs down faster. If your not using WIFI to read turn it off.
Yes. It does help.
i have a problem with my Onn. tablet
i was just playing a minecraft ripoff on it (that's not the point)
anyways i was only playing with it for a few minutes and my tablet shut down and it's battery was only at 80%
and i tried playing again and somehow the battery went from 80% to 14% in a few seconds
if i replace the battery,
do all of my games start over and i have to install them again?
@appleiocation78 no, it shouldn't be any different from turning the tablet off
that's not what i meant
if i replace my battery
does my games start over?
3 days ago by darth mango
i have no idea what that means :(
How long does my onn tablet charge
I have an onn tablet the battery goes from 100% to 1% in about 5min. It says hot remove battery which don't cause it's a tablet. I installed apps to cool down doesn't work
If your tablet last for 2 day battery life, It means you take care of it well.
i have an onn table but its battery goes from 100% to 15% to dead in 3 mins .the battery still drops whens it off.
I'm having this issue too
Like not dropping your tablet or phone. If you drop it a lot, it will reduce and damage the battery.
I want to know if my fire tablet wont charge if it has too many games on it that it won't keep charging
Recently, I found a ona19tb003 ONN tablet in an e-waste trailer. It has horrible battery life, and it is very slow. I was previously running a charge cycle of 10% to 100%. This made the battery slightly better, but it did not repair the battery significantly. In this article, I found that 60-80% percentage is a good time to charge the tablet, and it's good to not overcharge the battery.
I also found that by enabling developer options and making the memory buffer larger inside of developer options, it made the tablet faster. This can only be done if your tablet runs Android. I will note that some of the options in this menu may not be good for your tablet.
Someone asked if installing too many games on your tablet will prevent it from charging. The answer is no. They may use more power when you are playing them, and they might run operations when you are not using them, but they will not prevent your tablet from charging.
If your tablet is overheating, an app will not prevent your tablet from overheating, or it will do very little. Instead, look into the app that is causing the overheating. Try turning graphics settings down.
Son 24 Saat: 6
Son 7 gün: 9
Son 30 gün: 26
Her zaman: 19,926
1 Yorum
now my onn. tablet
shuts down a few seconds after i turn it on
and it's at 93% or charge
AppleIocation78 tarafından
