Ana içeriğe geç
Flywheel removal to replace sheer key
I need to remove the flywheel on a Briggs and Stratton 5 hp engine to replace the sheer key. I have done this before, but I can't remember if the threads on the shaft are right hand or left hand. I have removed the cover and part of the pull cord start assembly. The body keeps the flywheel on and I have not been able to un screw it!
The engine is back firing through the carberator that I'd how I know it has jumped time.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
1 Yorum
Thank you! When the righty did not work, too tight I guess, I thought it was time to check with someone else. I will bear down this time!
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
smithron4 just checked on one of mine. "righty tighty lefty loosy" So CCW to loosen the nut should work
Bu yanıt yardımcı oldu mu?
Puan 2
Yorum Ekle
Yanıtını ekle
smithron4 sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 7
Her zaman: 289
