Ana içeriğe geç
AMD Athlon 64 X2 1.9 GHz processor, 3 GB of RAM and 250 GB hard drive. Also covered with a 56k modem, integrated Ethernet and Atheros 802.11b/g Wireless LAN.
How do I remove the battery?
Hi,
How can I remove the battery? I think the battery is dead all the time even after charging it overnight.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
1 Yorum
Is There Any Way To Post A Picture Of Your Laptop - Preferably The Bottom.
tarafından
Yorum Ekle
2 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Normally Laptop Batteries Have Slide Locks That Hold Them In. Take A Look At The Bottom Of Your Laptop.
Please Note Image Is Not The Same Model As Yours - For Part Identification Purpose Of Battery Removal Tabs
There Should Be Sliders Like The Ones Shown In The Picture.
Once You Slide Those To The Unlocked Position The Battery Should Come Out After.
Upon Getting An Actual Picture Of Your Laptop. I Can Further Assist You
Bu yanıt yardımcı oldu mu?
Puan 1
1 Yorum:
Hi,
To add to Carl's good answer, here is a link to the user guide for the laptop which shows how to remove the main battery.
https://www.manualslib.com/manual/203306...
tarafından
Yorum Ekle
The battery is the long rectangular outline on the underside of the laptop towards the screen hinges. There are two pill shaped switches close to the battery that have labels 1 and 2. For switch 1, slide it to the unlock position (specified in the small diagram next to the number). Next, slide switch 2 into the unlock position (also specified by the small diagram next to the number) and hold it in that position (it is spring loaded so the switch will return to the lock position upon release). While both switches are in the unlocked position, use your fingers or a thin, sturdy object to lift the battery out from underneath the indent between the two switches.
Puan 0
Yorum Ekle
Yanıtını ekle
Sing Yang Cheng sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 4
Her zaman: 154
