Ana içeriğe geç
12.1" business laptop released in June 2012 by Lenovo. This laptop uses multiple product numbers, which vary based on configuration.
Why isn’t my Thinkpad charging?
The Thinkpad is properly plugged in at both ports but is not building a charge at all.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
1 Yorum
student question
tarafından
Yorum Ekle
2 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Test the power cord with a multimeter like in this guide.
Testing Power Cord Continuity
Then I would also test the power adapter is it is working with the multimeter
How To Use A Multimeter
If both test work fine then you know that your power adapter is fine and working.
You should also look at the power connector on he laptop so it is not loose because then the soldering might not lead the electricity. Good lock in testing.
Electrical Görseli
Kılavuz
Zorluk:
Çok kolay
1 - 5 minutes
Electronics Skills Görseli
Kılavuz
Zorluk:
Kolay
5 minutes
Bu yanıt yardımcı oldu mu?
Puan 2
Yorum Ekle
Try replacing the battery or buying a new charger.
Puan 0
1 Yorum:
Try pressing and holding down the power button for 3 - 4 seconds with the battery removed. Then try putting the battery back in, along with the AC adapter and see if it will charge. If this does not work try updating your motherboard.
If none of this works then try purchasing a new battery and AC adapter.
tarafından
Yorum Ekle
Yanıtını ekle
Lino Virgen sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 5
Her zaman: 408
