Why is my laptop heating up and turning off shortly after?
My laptop seems to heat up very quickly while I use it and it eventually shuts off. After waiting for a bit and turning my laptop on it repeats the same thing.
Bu iyi bir soru mu?
Bu iyi bir soru mu?
Your fan may be failing. I would listen to see if you can hear the fan running when the computer is performing a task. If the fan is silent, it may need replacement. Try following this guide: Acer Aspire 5742 Cooling Fan Replacement
Bu yanıt yardımcı oldu mu?
i think you have to clean your Laptop
here a teardown instruction guide for your laptop
same problem here .. i opened up the laptop cleaned it new thermalpaste (cpu - gpu) replaced the old thermalpads with new ones the cpu fan is working just fine (speeds up speed down) BUT in 10 minutes shuts off even in bios screen ! any ideas? thanks ! the laptop is Acer Aspire 5742
Son 24 Saat: 2
Son 7 gün: 6
Son 30 gün: 7
Her zaman: 562
3 Yorum
hey bro i have the same exact pc and face the same exact issue at first i thought it was an OS issue so i put windows 10 but still continues so what i did was teardown the pc completely and whe i reache the processor i cleaned up the dry hard thermal paste and made sure to smear the moist paste on the processor cpu and gpu or if u can u can put new paste it solve ma issue
mposha tarafından
ark tarafından
The Acer Aspire 57xx series (especially the 5742s) are well known for running very hot, mine shut down a few times as well. You could replace the fan and heatsink (requires system board removal) or set a lower maximum CPU speed in the power plan/BIOS (negating any advantage of choosing an i5 model over a basic Pentium).
spotify95 tarafından
