Ana içeriğe geç
Model A1224 / Mid 2007 and Early 2008 / 2, 2.4, or 2.66 GHz Core 2 Duo processor
Is my machine motion sensitive?
I picked my iMac up a few cm above the desk it sits upon and tilted it a few degrees in all three dimensions and it shut itself off. I am certain that the power cord did not become temporarily disconnected. Other than the power cord the only other peripheral connected was the wired apple keyboard with the wired apple attached. No connections are/were loose. My computer has never sustained any physical damage. It has not shut itself off since, but I have not tried to reproduce the situation since it results in a hard power off. Is this model of the iMac designed to react this way during this situation?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan -1
Yorum Ekle
2 Cevap
Filtre ölçütü:
En Yararlı Yanıt
You mean
Like this?
Yes there are SMS (sudden motion sensors) on Intel iMacs - but moving any running computer is still an excellent way to destroy a HD.
Remember to return and mark accepted the answer that best solves your problem.
Good luck,
N
Bu yanıt yardımcı oldu mu?
Puan 2
Yorum Ekle
You iMac should not be motion sensitive. You may have moved some component when moving it. If you do it again I would shut down first.
Puan 2
Yorum Ekle
Yanıtını ekle
xanthus702 sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 3
Her zaman: 891
