No engine light on dash
having problem engine light will not turn on with key on have two of the same trucks one does the other does not and i cant read the codes
Bu iyi bir soru mu?
Bu iyi bir soru mu?
miz4getful, check the bulb for missing/loose/burnt out(exchange it for a known good working one and check the instrument cluster back side for damage, burn mark,corrosion, solder joint break, etc. and if OB2 port is not working check your cigarette lighter fuse for being blown. Good luck.
Bu yanıt yardımcı oldu mu?
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 2
Her zaman: 120
3 Yorum
miz4getful, See Brandon B. and oldturkeys answers above or Re POST year, make, model,engine, transmission and complete question so we, here at ifixit can answer your question effectively.
L Pfaff tarafından
@lpfaff1 really? Another Canuck! Well, greetings from an expat.
oldturkey03 tarafından
Thanks for the greeting oldturkey03, all the leaves are down, you know what comes next, have a great day.
L Pfaff tarafından
