Ana içeriğe geç
The GE Profile Tri-Temp is a free-standing water dispenser with an integrated chilled compartment.
GE Profile Tri Temperature water dispenser will not heat water
Will not heat water, even though hot water switch is in on position (l). Water dispenser is plugged in. Instructions warned that hot water function would be destroyed if hot water tank ran dry. This never happened. Unit purchased Sept 2004. House fuse is not blown. (Electrical outlet functioning & green light on unit is "on") Checked to see if temperature limiter was tripped by setting hot switch to off (O) for five minutes, and then set to on (l) for 30 minutes. Red hot indicator light on front of unit does not turn on indicating heating cycle.
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
8 Cevap
Filtre ölçütü:
Seçilen Çözüm
Overload switch
If the wall socket has power, check to see if there's an overload switch on the hot water dispenser housing. If there is, reset the switch (usually by pressing it in), wait 15 minutes, then try the tap and see if the water coming out is hot. If there's no overload switch, there may be an internal fuse on the unit. To see that, you need to remove screws and a panel.
Heating element
If there's no overload switch--or if the unit still doesn't heat--the heating element may be burned out. If so, it may be replaceable. We would need your Model number to find the correct parts.
Bu yanıt yardımcı oldu mu?
Puan 5
2 Yorum:
good answer +
tarafından
It is GE Profile PXCR33KSS Hot and Cold Water Dispenser Cooler. I see three lights are green, but only the cooler is working while the hot line is regular. I think the heating element may be burned out. Please let me know how to order its "heating element"? Part number and what website? Thank you so much for your help. God bless you for always.
tarafından
Yorum Ekle
I have the same problem. My model# is GXCF25FBS.
Puan 0
2 Yorum:
see the above answer if you have the same problem
tarafından
The heating element seems to be the problem most of the time. Good luck finding a part though, unit designed to be thrown away.
tarafından
Yorum Ekle
The green light is on, but red one is not, even I switched the position between O and I several times. I always kept a water bottle on it.
Puan 0
Yorum Ekle
i click the hot switch to 0 for 5minite than switch it to 1 for 30minite. Now nothing working not even the cool water coming out which mean no water hot or cool coming out.
Puan 0
Yorum Ekle
hot water on GE profile dispenser won't heat up.
Puan 0
Yorum Ekle
where is the internal fuse was place at water dispenser
Puan 0
Yorum Ekle
Mine won't cool the water. :-(
Puan 0
2 Yorum:
And the refrigerator compartment won't either. :-(
tarafından
Care 717.. did you get any response.. I have the same issue
tarafından
Yorum Ekle
Model PXCR33KSS: There's only one switch in the back for power, no hot/cold. Cold water doesn't work but hot works. Just pulled it apart and the water inside was frozen solid….
Puan 0
Yorum Ekle
Yanıtını ekle
Dave sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 21
Her zaman: 21,837
