Ana içeriğe geç
Huawei's 2016 flagship smartphone. Features a unibody case and dual rear-camera setup developed in partnership with Leica. Comes in 32/64 GB storage options and six different finishes. Model numbers EVA-L29, EVA-L19, and EVA-L09.
71 Soru Tümünü görüntüle
Pre-cut adhesive alternatives. What should we use?
Hi,
I was asked by a friend to replace the glass on his P9. All went well till the part where I had to reattach the assembly to the metal chassis. Since I couldn't find pre-cut adhesive, I used the classic double-sided tape for the top and bottom edges (3M). The thing is, the bezels are so narrow that the 1 mm tape would prevent the screen from fitting properly. Eventually, I glued the assembly using only the top and bottom edges. It seems to be properly fixed, but the sides have gaps and that's kind of annoying.
Q: What can I use to glue the narrow sides of the assembly to the chassis as an alternative to the traditional pre-cut adhesive? I read about gel glues (B7000, Gorilla Glue etc.) but I'm worried that the glue will get in between the polarizing films of the LCD.
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Are you really gonna mess around to save $1.99?
http://www.witrigs.com/custom-lcd-suppor...
Bu yanıt yardımcı oldu mu?
Puan 3
3 Yorum:
I appreciate your answer, but the customer needed his phone ASAP. There wasn't enough time to get one.
tarafından
What kind of double sided tape was used? The black one or the transparent red tape? The red tape appears to be more effective when it comes to having them stick on the frame on huawei devices.
tarafından
Black, 3M made.
tarafından
Yorum Ekle
Yanıtını ekle
Ciprian R sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 16
Her zaman: 932
