Ana içeriğe geç
Mid 2006 / Model Number: A1181 / black or white case / 1.83 or 2.0 GHz Intel Core Duo processor
418 Soru Tümünü görüntüle
My A1181 just started displaying "overscan", parts of image missing.
I've got a modestly old MacBook A1181, the model that had a dozen siblings with slightly different features but shared the same designation.
Overnight, without any fuss or muss, the display went into an "overscan" mode. In other words, the image on the actual screen is only about 80 percent of the full picture and
about 20 pct is "off the edges" (numbers nominal).
I can still bring them up by sliding the window, so to speak, around, but that's very unfriendly
Any ideas how to reset this? I tried a bunch of tricks, including reinitializing the PRAM [a]. No good.
Thanks muchly.
[a] rebooting while holding down command-option-P-R
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
You could actually try to go to the service centre. They will usually know about the problem and can help you fix the laptop. This method needs a little bit of cash.
Bu yanıt yardımcı oldu mu?
Puan -1
1 Yorum:
@ctaneshaa you are the service center on here. If you do not have a solution or a valid answer, consider not to answer.
tarafından
Yorum Ekle
Yanıtını ekle
ifix2009 sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 2
Her zaman: 46
