How do I find Top dead center
I need to know how to find Top dead center on an 88 GMC. does anyone know how? Do i have to have a timing light?
Bu iyi bir soru mu?
Bu iyi bir soru mu?
If your just looking for TDC you do not need a timing light . first you need to find the number one cylinder then remove the spark plug . Turn the engine by hand (use a socket and bar on the crank shaft ) until you have compression stroke . You can tell by putting your finger over the hole and feeling the air push against it . Once you have the compression stroke look on the crank pulley , there will be a mark to indicate TDC. align this mark with the timing mark , usually just off to the side of the pulley with makings on it. This video should help
Bu yanıt yardımcı oldu mu?
Son 24 Saat: 2
Son 7 gün: 53
Son 30 gün: 203
Her zaman: 16,271
