Ana içeriğe geç
The G4 Quicksilver came in 533MHz, 667MHz, 733MHz, 800MHz, 933MHz, And 1.0GHz speeds.
49 Soru Tümünü görüntüle
When door closed is not booting and you cant hear the chime
But when the door is open and laid flat.It will boot and you can hear the chime and you will see the startup icon.
I checked all the power supply cables and HD cables , But are all fine.
Is there a switch some where ? I thought it was the other way around ...Meaning when the door is open should not boot
and when door closed should
Please help.
Thanks,
Peymon Gorkani
Bu iyi bir soru mu?
Puan -1
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
There is no door opened or closed switch. It should boot either way. Lay it on its left side and try starting then open the door and try. Please tell us the results. Also, when not starting do you get a light on the power button or any sounds or other lights?
Bu yanıt yardımcı oldu mu?
Puan 3
4 Yorum:
a good start +
tarafından
Ok , No Chime sound when not booting , But yes the Switch light will blink and the light on Cinema 17 inch switch also lights on , But no display...
tarafından
Ok I found the problem...There are 4 Holding screw sockets under the processor Board (Remove Heathsink then the board) Those were very loose and almost of the plate , Tighten those and reassembled and all is well now...Thanks
tarafından
Glad your problem got solved.
tarafından
Yorum Ekle
Yanıtını ekle
Peymon sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 3
Her zaman: 815
