Ana içeriğe geç
The Nikon 1 AW 1 is a waterproof camera manufactured in 2013. This camera is Wi-Fi capable and records in 1080p with a 14.2 MP lens.
7 Soru Tümünü görüntüle
Why doesn't it connect to wifi anymore?
I was using my Nikon 1 AW 1 the other day and I had no problems connecting it my home wifi. However, today I go to use my camera and now it won't connect. Is there anyway I can fix that or do I need to replace the camera completely?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Great question! Firstly, make sure you turn the camera on and off to see if that helps. If not, make sure the settings are set to allow wifi connectivity. If neither option helps, then you can certainly repair that without having to replace the whole camera, though it will take a little work. If you replace the motherboard then the wifi components (drivers/hardware) will be replaced with it. You'll only need to buy another motherboard for the Nikon 1 AW 1. Here is a detailed guide on how to do it yourself!
Nikon 1 AW 1 Motherboard Replacement
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
Joshua Bohorquez sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 4
Her zaman: 179
