Ana içeriğe geç
Chevrolet Cavalier, 1982-2005 yılları arasında General Motors tarafından üretilen kompakt bir otomobildir.
Why does it pull to one side when brakes applied?
The car hase been to several repair shops and everything to do with the brakes have been replaced. Calipers, hoses, rotors, pads, and even one shop replaced the lower arm bushings. No one can figure it out!
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan -1
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
If it's
been in an accident it could be a bent frame, or alignement (photo looks as if passenger side has been dented) it could be the power steering pump has a blocked port or crimped hose.
Remember to return and mark accepted the answer that best solves your problem.
Good luck,
N
Bu yanıt yardımcı oldu mu?
Puan 1
3 Yorum:
That's the iFixit photo for the device page, not this person's exact car. Good eye, though.
tarafından
Thanks and no its not been wrecked and that photo is not it. Car ran straight and true for years and then it just started the pull. Seems if you jab the brakes it pulls hard at first and then comes out of the pull as the braking is continued. I am leaning toward a bad master cyl or ABS unit maybe.
tarafından
@mark35955 try flushing brake lines they might have trash in it or pinch in like or one caliber is sticking
tarafından
Yorum Ekle
Yanıtını ekle
mark sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 23
Her zaman: 1,208
